Im thinking of getting an antec 900 as a case for my new system, but i hear its noisy, and takes in a lot of dust.However, what i want to do is replace the 3 120mm fans with ones which dont let so much dust in, and are quiter, so could anyone reccomend some decent fans for me.
Im going to remove one of the HDD bays but keep one of the 120mm fans on the front, if you can mount a fan there without the HDD bay, which i asssume must be possible (first time im building a pc so i dont know too much
Il also be using some paxmate on most of the inside of the case, because it looks better and.
Finally, i may be wanting to change the side panel with the window, by bascially removing the perspex and the grill, cutting the panel so the window is square, and then getting a new sheet of perspex and reattatching this to the side panel.
I am not too bothered about space inside the case, or the noise, but removing one of the HDD bays should open up some space i geuss if i do want to make it watercooled at a later date. For the case, the paxmate, the fans and the perspex it will probably come to around 100 quid, so i could just go for an akasa eclipse, but then id want to do the same with that. I also want a case which looks alright but isnt the same as everyone elses, and i wouldnt want to spend much more than this on a case really.
Basically is this a decent case if i make a few basic changes to it? i just want a case that looks alright, doesnt get too much dust in it. But im not too bothered about the noise. So should i get the 900 or just get an eclipse and leave it as it is?
Thanks for any help, and sorry about the long post
)Il also be using some paxmate on most of the inside of the case, because it looks better and.
Fantastic looking case and all panels including the top are removable, extremely easy to access all areas of the case, cooling is exceptional, buy one or get an Antec 900 and experiance the cramp-ness and its superb dust collecting properties...
