Antec 900
26 Aug 2004
Does the Antec 900 have a hard drive activity led and also power led?
Anyone got a picture of how it looks?
I'm thinking about upgrading to the Antec 900 from my Thermaltake Soprano.
Nope. But then again, do you really need one. I just use a spare that i have if anything ever goes wrong. (Which it doesnt).
You dont need a power led with the 900, it has 2 blue LED 120mm fans on the front.
Er, with regards to the power LED you're going to know this thing is on save for the fact that there's a slightly noticeable whoosh of air it also glows blue or.
The HDD LED is positioned on the top to the left of the USB ports and just to the right of the reset button. It's also blue and quite strong.
Not really, just take your time, and do it slowly. You can move all the drive bays forward a bit to give you more room, if you need it, and there are 2 built in ties up the side of the motherboard. The motherboard main connector can be a bit of a pain, but other than that it's really quite good, I can look through the fans on the front and see my whole m/board.
