Antec 900!
3 Jul 2007
Rochdale/whitworth
iv just oreded a Antec 900 to replace my Antec Sonata III due to my computer getin to hot. Do you guys think its a good upgrade ?? and any one got any pics and help for cable tidin in the 900
Cable management of the 900 is difficult, but there are a few people on here who've done it well. There's even some people who've managed to fit watercooling in it!
I wen't for the P182 over the 900 just for noise and cable management, and i'm happy. Plus it knocked 15 deg off my temps from my Akasa Zen I had before.
Advice with cable management is, plan everything BEFORE you start, and make sure you have a lot of cable ties handy, preferably in a colour of your choice!
Do you have a modular PSU?
I had 2 holes put in the bottom of mine. Next to the power supply under the motherboard. Helped with the cable management.
Only problem area was the 12v cable to the CPU, there is no way to get that around the back of the case and therefore has to go over the graphics card.
I have got my 12v cable going nice and tidy to my cpu... look
infact yeah I would also love to see a good cable system in place. The one above is cool but I have 6hds and a big gfx card. Cables def arent tidy!
