- 16 Nov 2009
- Middlesbrough, UK
Hi All,
I have an antec 902 case with a corsair h50, With the 902 pre installed fans there are some small black cables with a little switch on them that clip into the back of the case with L|M|H adjustment on the switch so u can adjust the fan speeds via the switch at the back of the case.
With the h50 tho this cable is pulling and constantly unclips from the case and falls inside?
Well Im going to be getting a new 5970 soon and was wondering if anyone could suggest one of them fancy fan speed adjuster thingmies that slot in one of your cd trays that allow u to adjust the fan speeds? Or would I need new fans to do this aswell? How do these units connect to the fans exactly?
Many Thanks!
Many Thanks!
