Antec 902 - control fans from mobo?
5 Nov 2003
Hi again. My 902 fans are controlled by a switch at the back of the case (silent, medium or high speeds). I was wanting to build a rig that could be controlled automatically by the mobo temperature sensors so I was wondering if the case fans could be converted somehow to be controlled by the system rather than the switch. Any idea?
Cheers
It depends if your motherboards capability to control a fan by DC voltage rather than PWM. Essentially you'll be plugging in a two wire fan (via adapter) into a 3/4 pin header. You'll get no speed feedback and if it's pwm only you'll get 100% speed all the time. It might be more realistic to use a manual fan controller up front using adapters.
