Hi guys,
Had a new tower from OC for about 8 months now. Having no issues but noticed the front dust filters on the 902 are starting to look a little dust clogged. The side fan's filter is likely also the same. Should I take the time soon to give these a good clean or is it not particularly important? Air flow seems fine so it's not like the dust on the filters has started to block air intake or anything.
Cheers.
Cheers.
