Antec 902 - filter cleaning
8 Nov 2009
I must be stupid but I can't find a way to get to the front filters to clean them.
Looked at the Antec manual and it refers to removing the HD cage. :confused: So, for a complete noobe who's never unscrewed the case can you please explain the proceedure. Thanks.
Remove side panels, remove 4 silver screws on each side of HDD cage and slide forward, which will then let you take filter out (from top of cage), also to save time in future, when you put filter back and slide cage in, don't screw it back in (with 8 screws), so when you want to clean filters again, simply slide HDD cage out etc...
You don't need to remove the HD cage unless it's full of HDD's. If it's not just squeeze your hand through and push the fan/filter assembly from behind and it will pop out.
