Antec 902 help
23 Feb 2010
Hereford
Hi guys, can somebody please tell me where i can get the side panel on my antec 902 sorted out? i just want it as 1 big window so i can see all the goodness inside!! i dont have the tools to do it myself so any suggestions?
cheers, james xx
Get some tools.
Dremel.
File (half round)
Sticky tape.
You could also use a jigsaw instead of the dremel.
Sending your side panel off to be window missed will be expensive I'd imagine.
