Antec 902 LED lights
7 Nov 2009
Hey guys I recently got an Antec 902 rig
could someone tell me how to disable the LED lights?
It has 2 green ones in front and a blue one on top.
I don't want to cause any damage (ive lost the knowledge of building comps) but I would love for these lights to go off as sometimes i sleep with the computer on and the lights are quite bright :p
The top one can be turned off with a switch at the back.
The rest of the fans that come with the 902 can't be turned off, But it sounds like you have replacement fans. There are also very few fans that can have the LEDs turned off, So you will most likely have to keep them on or cut the wire to the lights, Which will mean permenantly turning them off.
I have an Antec 1200 and the lights aren't that bright, not enough to make me loose sleep over.
Why not put your pc against a wall like I have or put it somewhere you wont see the lights from your bed?
