Antec 902 MATX Question
18 May 2010
Hi,
I'm looking to upgrade my PC on a budget this Christmas and will be looking at swapping out the Motherboard, RAM and CPU and keeping the case, GPU and PSU
As I want an MATX case next year I was wondering, how do I know if my current Antec 902 will take an MATX motherboard? I don't know what version it is unfortunately, is there any way to find out?
Thanks
Yes, ATX just has a few more holes, ITX will fit as well but use even less, this graphic should help clear it up for you.
