Antec 902 V3 restart button not working
29 Nov 2010
It's never worked sinced I made my PC, it's the big one on the right side, although you would assume that to be the power button. It litrally does nothing currently, I press it, hear a click, feel the resistance and... nothing. Anything I can do? I think I connected the wires up properly.
Um unless its all changed when it was revised the big button on the right IS the power button!! Re-check mobo manual make sure its in the right header....
Was thinking the same the bigger button is on/off smaller button reset.
Double check you have connected to the correct headers.
Well the big one is the power button if you connected it to the power headers on the mobo. Sounds like you didn't do the connections right.
