Hi everyone.
I bought myself an antec 920 a week or so ago, and since installation it has been on and off making a rattling noise (kinda like a fridge). I read a 'fix' on the web that involved laying the case flat, running it for a while, standing it up and the problem should be solved...tried it, didn't work
. It may have actually made the issue a little worse.
Anyone know of another fix that might be possible for the noise? It's louder than the 5 other fans + the gpu fan put together at the moment
. I got it because of claims it was quiet. Should have stuck with my stock intel cooler
I don't really want to RMA it either to be honest.
Thanks in advance.
. It may have actually made the issue a little worse.Anyone know of another fix that might be possible for the noise? It's louder than the 5 other fans + the gpu fan put together at the moment
.I don't really want to RMA it either to be honest.
Thanks in advance.
). Someone fixed it with a magnet on youtube but to be honest I don't want to go sticking magnets to things inside my case.
. And I just hope it's sorted now
