Having an absolute mare with attaching this cooler. It came today from overclockers but once the mounting bracket is installed the heatsink clips do not align at at all. It fits fine when it's off the motherboard.
I can angle it to get one side on but then it lifts the other way too high.
Any ideas other than sending it back?
Not sure if it's because the brackets are resting on the capacitors maybe.
