Antec homepage - http://www.antec.com/product.php?id=706179&pid=105
OcUK product page (red) - http://www.overclockers.co.uk/showproduct.php?prodid=CA-187-AN&groupid=703&catid=1939
OcUK product page (blue) - http://www.overclockers.co.uk/showproduct.php?prodid=CA-188-AN&groupid=703&catid=1939
Here is a quick look at Antecs accent lighting LED strips.
They are designed to add a soft glow in either red or blue via 6 leds on each strip, these are very simple to use and are powered by USB with an ON/OFF switch near the USB connector and a simple adhesive backing to stick wherever you want them to add some mood lighting to either around the back of your monitor, under your keyboard or underneath your case.
Product packaging.
Contents.
Closer look.
ON/OFF switch, really nothing to say here.
370mm long.
So you can cut them to length if they are too long for you.
How they look in the dark.
This is quite hard to photograph something in the dark so I will do my best.
They can be placed virtually anywhere to add a soft glow. But with two or more there's no reason why you can't get creative.
Final words.
For £8.99 these are a cheap and easy way to add a bit of mood lighting wherever you can stick them, if you have multiple colours then you can do some really creative ideas and still have the convenience of being able to turn them ON and OFF.
I think these would look good in if they came in more colours tho.
