Antec Aria Migration
14 Mar 2005
Here and There...
Now I'm happy with my new main rig I'm thinking about migrating my old PC into the above case to replace my mini-itx HTPC which may be silent but isn't the best for playing back movies or a bit of light gaming. My old PC is a 1.8GHz P4 (One of the first ones!) a cheap MSI motherboard thats the right size 512MB of PC133 and a radeon 9600PRO.
Just wondering if anyone had any experience with these Antec cases and wanted to encourage my purchase or point me in the direction of something else in a similar price bracket that would accomodate this sort of spec
Good case and you should not have any trouble with it.
If you like it, then I doubt you could find anything better. :)
It's a gorgeous case. Very nice to look at, miles better quality than the Aspire XQpack. Only the Silverstone Sugo beats it for me, but it costs mega-bucks.
You might want to be aware however, that your system will not run very cool, airflow does leave a little to be desired.
Is your P4 Socket 478? If so, I'd invest in a Zalman CNPS7000B Cu heatsink
Was wondering when you would show up :)
I agree completely with the comments about the Sugo, but out of the box the Aria is a bit quieter.
Cheers guys good to see some posotive feedback, definately worth investing in a new cooler mine is still on the stock and after 5 years of abuse it is nearing it's end. The Sugo is a little out of my price range, I'll let you know if I decide to take the plunge!
