Antec C5 Case connector query
23 Apr 2007
Cardiff-ish, Wales
Hi all, I'm struggling to identify the left hand connector in the image below. Any ideas? I've connected the right connector to Sys Fan, I can't spot any connectors on my mobo that will take the one on the left. Mobo is an AM4 MSI B450 Tomahawk Max.
Code:
<blockquote class="imgur-embed-pub" lang="en" data-id="a/iDqj7CZ" data-context="false" ><a href="//imgur.com/a/iDqj7CZ"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
this is by no means an expert opinion as ihev never actually held a cable with that layout, with the 3 out of 4 pin layout with the 3rd missing i think its an addressable rbg cable
and i seem to remember from a youtube video about case layout that a cable with that arrow on it, being part of a daisy chain thing
yep here u go
I assume that means it needs to go into a controller rather than the motherboard.
nah it should plug into the motherboard(inot the proper pin socket that is), the arrow part of it is to match with other arrows if plugging into another cable
could also plug into the controller too though
Ahhh. I can't find anything on the motherboard that will take it. I'll look again.
I've also spotted this connector as well. Any ideas?
Code:
https://imgur.com/a/PEB2loA
Code:
once again disclaimer, never held one but that looks like the front panel usb c connector
How you getting on with the case?
I got the white version to replace my 4000d, like the look and good airflow.
But I found the bottom fans made it hard to access connectors at the bottom of my motherboard and the cables for the 7 fans included are hard to manage.
Agreed, ARGB and USB 3. If your Mobo does not support ARGB, you can get ARGB device controllers off the web, they are controlled by button and plug into a SATA power connector. Don't try plugging ARGB in to a 4 pin mobo header as they are 12v not 5v.
The case already have a fan/argh hub included, for my case the 2 pins cable for reset button already connect to the hub to control the RGB.
