Antec case for 30cm graphics card
20 Oct 2002
Space, the final frontier
Currently looking at either the Antec 300 or the 900-2 case
But the graphics card going in is 30cm long (compared with 24cm with a HD4870)
Now it's only having one hdd to start with, so loosing one bay isnt an issue, but will the card actually fit with the power cables connected without touching the hdd cage?
will either of these cases fit this card in ok?
Thanks
This is my old Antec 300
And in close up
Looks like 28cm max there I'm afraid to say. I would fit with a little modding I'm sure! If the card would fit between the sides of the drive cage then you might just get away with it...
An alternative would be the Silverstone Fortress FT01B-W, yeah I know it's more expensive but it can take 12" cards like the nVidia Quadro's by removing the middle drive rack.
OH yes thats the one 4850x2 god damn that thing is big. I recently did a build for a friend in a antec 300 and I would say with almost certainty that card will not fit in there
