Antec case
1 Mar 2009
Can the Antec 902 be as quiet as P182?
Can you change the Antec 902 LCD fans?
i know cooling going to be better in a Antec 902 but is there a big difference in cooling compared to P182.
I love the look of the P182, really wanna use it to build my computer in but im worried it wont fit or cool my components very well.
im building a i7 920
graphic card Either 4870x2 or GTX 295.
only a single HD and optical
thank for any advice
Update: THe p183 any good!?
got a p180b wgich is basically the same as p182. And i have fine temps run prime 95 for few hours max temps are 42 with all fans on low. GPU temps are 60c but the fan is at 9% .
The p180b was really easy to work with and the p182 will be even easier.
Love the look of them one of my best buys for along time!
Yeah i love the look of the p182, simple and looks cool. 902 looks abit over kill for my room.
