ANTEC CP 850W - Change fan?
Im sure you will be able too, just be careful with shocks etc.
You don't wanna be dying on us :) I think its a week you will have to leave it for it too be 100% discharged, someone wanna clarify on this though?
Change the fan will kill your warranty.
Could also reduce the life of the unit too if it runs too hot.
That said I mod most of my power supplies just make sure the fans you swap out do shift air.
