Antec CX600M case fans
Caporegime
28 Jun 2005
On the hoods
I’ve just built a new PC with an Antec CX600M case and it’s all good. It came with fans already fitted at the side and back, and I’d like to put some more fans in the bottom… not because it’s running hot, more just that I want more cool flashy lights in the case… The intake fans in the side are called H12R, per the specs, but I can’t find any Antec fans for sale with that model number. Would any 120 fan do? Do I need to look out for anything special in terms of using them as intake fans rather than exhaust?
They are the same as the p12 argb. The r stands for reverse, meaning the fan blades are reversed for intake so you don't see the cables or supports holding the fan together at the back. All designed for aesthetics.
