Antec Dark Fleet DF30 side intake
2 Jan 2012
Hi, I've just got a DF30 case, it's absolutely brilliant and I love the filters at the front but one problem is the massive grill on the side where air can get in.
I'm wondering if anyone has found a good filter to cover the grill. I've seen the DEMCiflex filters but I don't know how well they'll work.
I've heard good things about them, and the company seems to be very devoted to that small field so I think that will work well.
Those DEMCiflex filters are excellent. I used mine to block up a side intake and it catches all dust - so much that I end up cleaning it every 2 weeks! :eek: (and I keep a pretty clean house before anyone asks :p)
How are yours fitted? my side panel has what are best described as feet that if a fan were installed bring it about 5mm more into the case so on the inside it's not a flat surface.
I don't know if you can tell from this image:
Also do you get 1 or 2 of the DEMCiflex filters from OC?
