Antec fusion LCD
9 Aug 2003
Liverpool
Receieved ths case today however after switching it on I noticed that the LCD is dislodged and it's on an angle now so I can't see the bottom right of the LCD. I had a look behind it and can't see a way to get into the LCD unit, does anyone know how to get at it?
You have to remove the front panel and in the top left hand corner is the lcd housing remove it. (3 screws and 2 push out clips)
Remove the back cover of the LCD on the left hand side 3 or 4 screws and you should have access to the LCD just place the film back in its holdings and re-attach everything.
It happened to me and it was relatively easy to do.
