Antec Fusion Remote Max
10 Apr 2004
Hi All,
Wondering if anyone has seen/owns this case. Considering it atm as it takes big coolers & full ATX PSU/Mobo's.
Looking to put 4870, QX6700, Corsair 620W PSU, Terratec Tuner,1 TB drive, LG Blu-Ray, Bad Axe2 Mobo & 4gb's ram. Dual Boot Ubuntu/Vista is the aim.
http://www.anandtech.com/showdoc.aspx?i=3427&p=8
Or anyone got any other alternatives as the cpu is one of the earlier quads and runs fairly toasty in my big tower case atm.
Cheers
This is SFF? :confused:
I notice that only the front plate is aluminium. You'd think if they were going to copy Lian Li they'd at least go for a full alu body.
You say that but according to the spec its 178 tall which compared to an LC17 (170) isn't that much difference - besides depends how big your amp etc is ;)
No problems installing all that. I recently purchased that very case and will be doing a review shortly. Plenty of room for dual graphics cards, even extra long cards.
The only negative I give it is that installing hard drives is a pain due to the clearence between the rear of the drive and the wall of the psu chamber. I used sata, I honestly doubt you could connect a molex.
If you don't want to wait for my review; check out someone elses in the mean time.
http://www.silentpcreview.com/article890-page1.html
Oh, and it really is huge. Not to mention heavy fully loaded. Hope you have something sturdy to put it on.
Cooling is the best I have ever seen in a case (using air), let alone a HTPC. Seriously.
