- 23 Apr 2007
- Cardiff-ish, Wales
Hi guys,
just fitted the motherboard to the case and am getting confused about some of the case connectors:
1. Power Supply 3 Pin Fan Signal Connector
The Antec book says that this blue & black wire connector fits into a FAN connector on the motherboard to monitor fan speeds. I can't find this cable anywhere. The only cables I can see from the fans are 2 large power ones.
2. M/B and Gnd single connectors
I've no idea where these go.
On the Front Panel Header on the motherboard I've connected:
Power Switch
Hard Drive Activity LED
Reset Switch
I haven't fitted anything to:
Message / Power / Sleep LED (MSG+ MSG-)
Power LED (MPD+ MPD- MPD-)
Not sure what these are ...
Any ideas?
Cheers,
Jed.
Power Switch
Reset Switch
Any ideas?
Cheers,
Jed.
