- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
Check out the reviews from Kitguru here
Antec HCP 850w review
http://www.kitguru.net/components/p...ec-high-current-pro-platinum-850w-psu-review/
Pros:
• class leading noise suppression.
• fully modular.
• anti scratch paintwork.
• high grade cabling.
• quality Japanese components inside.
• delivered over 1000 watts.
Cons:
• Its around £180
Kitguru says: One of the best 850Watt power supplies we have tested, and able to sustain a 1000W load.
Antec HCP 1300w review
http://www.kitguru.net/components/p...ec-high-current-pro-platinum-1300w-psu-review
Pros:
• fully modular.
• best quality components inside.
• monster +12V output.
• ten PCIe connectors!
• delivered over 1400 watts.
Cons:
• Its £300. (£240 at OcUK)
• A few more SATA connectors wouldn’t go amiss.
Kitguru says: If money is no problem and you need the best high power supply that money can buy, then this should be right at the top of your shortlist.
Pros:
• fully modular.
Cons:
• Its around £180
Pros:
• fully modular.
Cons:
