I recently put together an HTPC using an Antec Case and the Abit AN-M2HD motherboard. Everything is working fine, except a little niggle.
The LCD display in the case uses a program called VFD, which can connect to the net and download news and even the weather. All this works fine and so does the equalizer when I play music. (There is a setting for the equalizer where you chose the output and HDMI is listed.)
Here is the problem. The same program also controls the volume button on the case, but this tab only lists 'SPDIF' as digital output and not HDMI, so my volume button doesnt work.
Has anyone got the same case/motherboard/problem and could lend me a hand? Thanks!
