Antec + Icydock = YUM
18 Oct 2002
Cambridge, UK
Now I'm no case connaisseur but I think this looks wicked :)
HEADRAT
looks great !
but for starters what is it ?
could you explain ?
I think it's the iceydock internal enclosure fitted to an Antec 900 case.
The icydock enclosure lets you put 5 sata drives in an hot swap enclosure(there is a 3 or 4 drive version as well i think) and the enclosure takes up 3 x 5.25" bays in your case.
Looks pretty good. The only thing that lets a lot of these cases down is the 'cheap' looking facias that optical drive manufacturers use. Some of them are just horrible.
This would look great in this case:-
As the silver on the front would complement the release handles on the Icydock
But I'm not dropping £180.94 ;)
How much storage you got mate?
I am looking at buying this case with a dock myself as i want lots of storage but a good speed too :) and a really good sound card
edit: can i see a pic of inside too :D
Looks good! like the thought of the multidrive might have to invest inone for my media center.
Rob
that icy dock makes the 900 look very wrong.
perhaps if you installed 2x icydocks it may balance it out a bit more... or even 3 using all the bays may be the trick!
Although at almost 70 quid for each module it may be pricey too
