Antec ISK-100 mini-ITX Case
10 Nov 2008
Isle Of Wight, UK
Good day to you.
I am trying to find out if anywhere has used or knows much about the Antec ISK-100 mini-ITX Case.
I am trying to find out details regarding the power supplies.
From looking at the pictures and the details on this item, is that this case uses an external AC to DC PSU, and then an internal DC to DC PSU.
What I have not yet been able to find out is what voltage and current the external PSU is.
And if the internal PSU is safe to be connect directly to a 12Volt battery for use in a camper van.
Thanks for your time.
Best Regards.
Well I have just found the PDF manual for this case here: http://www.antec.com/pdf/manuals/ISK 100 manual_EN.pdf
And I have answered my own questions.
Rated Voltage: 19VDC.
Voltage Range: 18.4-20.0VDC.
Output Current: 0-4.7A.
So it will not work on a 12volt camper van system, so I will have to stick with a 12vdc to 240vac invertor, that is a shame as thats a waste of power.
