Antec Kuhler 620 noise
18 Oct 2005
Leicester
just got around to fitting my antec kuhler 620 as i wanted good performance and less noise....
well its all fitted but the pump unit makes a rattling sound like them old external air pumps you used to get on a fish tank years ago.
when i lay my case on the side it shuts up and goes quiet again
i take it that its a faulty unit? or are they meant to do that?:confused:
yeah its being rma'd
it was around 35c at idle and around 64c max on one cores the others were around 55 on a stock i7 2600k i dont think it was settled in yet though as the noise was more anoying then a stock fan so i removed it
Thats far too high on stock, its faulty.
