I have been looking at the Kuhler H20 and similar and wondering. How noisy are they? Are they quieter than a normal HSF? I have the Titan Fenrir at the moment.
I can't vouch for the khulers but the corsair hyrdo series with stock fans can be deafeningly loud, but you do have the advantage of using what fans you like.
You'd be hard pushed to find anyone who still uses the stock fans tbh
I have a Kuhler 620 H20 and I use 2 viper fans in a push/pull setup. I find the PWM function useful on the viper as they only run at full speed when the CPU is at full load. All other times I find them quiet, as they run at about 600-700 rpm.
I have the 920 and I can tell you it's quieter than my old fenrir running a Phenom II x4 955BE at 4Ghz 8 hour prime test temps stick at 50c and cooler fans stay around the 1100rpm mark
