Hi,
So Antec have decided to release the beginning of a new range of coolers to try and compete in the Air cooling market after the AIO Cooler had great success.
These coolers are the start of a bigger range and they have decided to release the budget friendly coolers first. The coolers are very easy to install and can handle themselves when running intensive CPU programmes.
They are the standard Intel and AMD socket support (Not 2011) and come with a Blue LED fan to add a little colour to your computer.
I believe Antec have done a good job with the cooler and have released them at a price point correct for the market they are aiming for.
All coolers are now in stock.
Antec A30 Dual Heatpipe CPU Air Cooler @ £11.99 inc VAT https://www.overclockers.co.uk/antec-a30-dual-heatpipe-cpu-air-cooler-hs-015-an.html
Compatibility: Intel Socket LGA 775/1150/1151/1155/1156/1366, AMD FM2+/FM2/FM1/AM3+/AM3/AM2+/AM2 CPU
Only £11.99 inc VAT.
ORDER NOW
Antec A40 Pro Quad Heatpipe CPU Air Cooler @ £19.99 inc VAT https://www.overclockers.co.uk/antec-a40-pro-quad-heatpipe-cpu-air-cooler-hs-016-an.html
Only £19.99 inc VAT.
ORDER NOW
Antec C40 Nickel-Plated Quad Heatpiped Direct Contact CPU Air Cooler @ £24.95 inc VAT https://www.overclockers.co.uk/ante...-direct-contact-cpu-air-cooler-hs-017-an.html
Only £24.95 inc VAT.
ORDER NOW
Antec C400 Quad Heatpiped Direct Contact CPU Air Cooler @ £29.99 inc VAT https://www.overclockers.co.uk/ante...-direct-contact-cpu-air-cooler-hs-018-an.html
Only £29.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
