Antec Mini P180 *Rebuild*
Up to your usual high standards Blackhawk47
What's with the Apple logo though?
And did you choose "1" or "2" in the end???
Man was that a rampant thread.
Ugh, yeah I really should know better not to venture into GD. :o
Might ask 1 but haven't done anything yet.
Anyway - back on topic. Thanks, basically the Apple logo was just a sticker...the black padding it is on I used to cover up the bottom section of case and the excess cable clutter from the PSU. ;)
EDIT: Added setup pic below. :)
I've just brought this and the side it says "gun-metal black finish". I purchased it as a black case. Now depending on the lighting conditions it does look black, but stick some light near it and looks greyer obviously.
Is there just 2 models available - gun-metal black and white? Or is there three? gun-metal/black/white.
Don't want to build it If I am going to have to send it back!!
The Antec pictures look black on the site. But on this review you can see what I mean:
http://www.bjorn3d.com/read.php?cID=1246&pageID=4688
OK this explains it better (I hope!)
Antecs pictures are deceptive, the case actually looks more like this in the flesh:
http://benchmarkreviews.com/index.p...sk=view&id=222&Itemid=61&limit=1&limitstart=2
Can anyone confirm this??? Or is there a black model and a gun metal model?
Hello Chappylads, got my P180 mini today so was porting my rig over here's what i got:
Sorry about the bad quality only had my phone to hand!
I need some ideas for a new cooling solution! Should i get a Corsair H50 for 40GBP or stick to air? If so what coolers fit - i'm conscious of the height restrictions!
Very nice build! Any plans for watercooling ;)? I can help you with info/parts list and what fits/not fits etc.
Also do you keep your dust filters in at the front? I find they tend to stop airflow quite badly and create a bit of noise aswel.
For best airflow - I removed the front panel completely and dust filters.. by doing this i actually managed to drop my temps by about 3c lol. Was going to cut 2 window holes on the front panel and then plexi glass it over with a design drawn into it but just not got round to it yet.
