Antec models
Vol
Vol
2 Feb 2004
Quick bit of advice plz.......
Building a SFF and am prolly going for the Qpack or an Antec
OCUK are stocking the Antec NSK 1300 but most reviews talk about the Aria
So....
  • Is the 1300 the later version?
  • is the 1300 better than the Aria
  • Any opinions as which is better between the QPack or Antec?
Thx in advance
/ Vol
The 1300 is the later version of the Aria. As far as I can tell it is almost idendtical to the Aria, but has no card reader or front firewire adn has an exrtra vent on the top. The top vent will do precicely nothing for internal temperatures as it is for the PSU.
I own an Aria, and it works perfectly for me. I modded an 80mm blowhole in the side and the temps are very good for a small case. The build quality is good and there are no vibrations.
Personally I'd go with the QPack, it's a bit uglier and not as good build quality but there's much more room, and cooling is better.
