Antec Nine Hundred Power LED?
22 Jun 2004
Bangkok, Thailand (formally London)
Howdy,
Fitting together my new PC... and I am hooking up the panel connections, and I'm looking for my Power LED connector on my Antec Nine Hundred case... and it doesn't exist? Is this right?
I'm looking for PLED+ and PLED- or PWR LED... is it called sumin else on here? Cos I'm pretty sure its not there?
Any help will be appreciated!
ta
If I remember from when I had my 900, some of those jumper cables were unmarked. I think you'll be looking for a jumper 3 pins wide with 2 cables running to the head. The cables run to the two outside pins, with the middle one being empty. Thats if I remember correctly and its the same as my Lian Li PWRLED.
im sure it doesnt have it...if its a three pin one...then it isnt there. Dont worry about it.
I'm trying to remember what the LED on the top of the case did. I think it may have been the HDD LED and that there was indeed no PWRLED.
the little blue light on the top is the HDD LED...you know when the system is on cos the two big blooo fans at the front light up:D
Exactly what I thought... the reason I was a bit confused is cos in the Antec manual it tells you to connect the power led connector?
Oh well, thanks peeps!
all I can say is...been there...done that!I too was looking for my Power LED cable when I built a system with the 900...LOL.
If you wanted power and no hdd then just swop the plugs over. Considering that there is 2 x LED fans in the front . . . THATS your power leds right there . . . . . .
