Antec Nine Hundred
Not sure if its the same length as the 4850 as these are pretty long themselves, but it fits fine as does a 8800GTX so I'm sure it'll fit.
Edit: Apparently 4850/4870 are same length, so yes I can confirm they fit.
Have a read through this thread. Contains a number of different views on the Antec 900. Personally I find the case ok. Not a lot of room to work with with 3 HDD's and SLi 8800GTX's, it's a bit noisey and it gathers dust like a mofo. If you don't have very much kit in it though it's probably a good option. Oh and make sure you get dust filters, it really does suck dust up like a hoover.
