28 Jan 2010 at 10:23 #1 ViperZS ViperZS Associate Joined 20 May 2009 Posts 383 Location York Hi all I'v got an Antec 900 at the moment, with all fans on *high* It's pretty loud now. is it a case of new fans or new case to get it quiet? Cheers, Tom Last edited: 28 Jan 2010
28 Jan 2010 at 10:26 #2 siumatfung siumatfung Soldato Joined 5 Mar 2009 Posts 5,402 Location North East have u tried cleaning it out~? normally dust can be the cause of most noises but generally all the fans set on low is inaudible so you either have sensitive hearing or your not turning them on low
28 Jan 2010 at 10:27 #3 ViperZS ViperZS Associate OP Joined 20 May 2009 Posts 383 Location York siumatfung said: have u tried cleaning it out~? normally dust can be the cause of most noises but generally all the fans set on low is inaudible so you either have sensitive hearing or your not turning them on low Click to expand... Hi, cheers for the reply just realised i made am istake. Fans are on high! silly me
28 Jan 2010 at 10:34 #4 EsaT EsaT Soldato Joined 6 Jun 2008 Posts 11,634 Location Finland Also that cheese grater case is problem for lowering noise. It leaks out every slightest noise entirely unmuffled.
