I'm building two systems today - work & media center
I'm trying to see which way is best to fit the AC Freezer 64 Pro into my Antec NSK1300.
With the fan on properly the heat sink touches the PSU - this results in the heatsink not being perfectly vertical and I am concerned about putting slightly uneven pressure on the CPU (Athlon 3700+)
With the fan off and the heatsink turned 180 it seems to fit fine - perfectly vertical and no touching. I could attach the fan to the otherside of the heatsink (using tape etc) and all would be well?
anyone else come across this issue?
Thanks
Thanks
