The PSU should be ok to run a system like that as average peak load consumption will probably be around the 230W mark for the whole system, assuming stock values.
But don't count on it surviving spiking/pitching if you're playing a game, or lasting a long while if you're going to be CS-Source'ing 24/7. But - as long as the 12V rail is up to the job then you should be ok.
