antec one case
31 Aug 2012
i want to put a 7950 graphics card in, its 288mm long and the case claims its maximum is 266mm, ive been linked a foto of the case with a graphics card in it but im unsure,
if anyone knows would be a great help?
Usually 288mm into 266mm won't go.
If you're doubting the picture then upload it to an image hosting site and post it here.
We can judge for ourselves then.
The fact that the graphics card in the picture says GeForce on it tells you it isn't a HD 7950.
Anyway, the MSI HD 7950 Twin Frozr III is 261mm long.
Not sure if the V2 OcUK now sell is any different.
ahh right, yeah i know it isnt a 7950 lol, just it had a graphics card in it, im just guna buy the msi one off here and hope for the best really, i can just mod the case im not that bothered really, was just guna xfare 2 7870's but id rather spend the extra cash and not bother with the hassle as im not very good with pcs if im honest
If you're unsure about anything perhaps you should list the full specifications of your system so we can check all will be well.
