whats the ETA instock for OCUK , other sites are showing 27th/28th of this month?
My basket at Overclockers UK:
Also stock is booked for delivery into OCUK tomorrow.
Maybe I will post you a nice goodie if you do thatOK 99% Gonna get one... better hope nothing else comes out in the next few days, is there a prize for the first build pics![]()
Really happy that you like it, but it is top quality in terms of the materials and the design too.Yep pre ordered a few weeks ago when the case was announced on here.
Lovely finish to the front panel with the brushed Aluminium and with the side vents removed i don't believe i will have any airflow issues, I get the impression that the top dust cover might be a bit marmite but i definitely like it. It looks like the fan mounting holes are slotted instead of pre drilled holes so i can set my rads and fans at a whole range of different positions to suit my loop and the cable cover should make res mounting easy and flexible as well. Nice weight to the case, nothing feels cheap or poorly made and as there is a blacked out edge to the tempered glass you can re fit the panel without worrying about finger prints on the inside!
140mm fan in the rear would have been nice and unfortunately my Noctua fans will be on full display as well so need to find a way to paint them black (or anything other then Noctua beige) or purchase new ones.
