Antec P180 cable management
5 Dec 2006
I've had an P180 for 6 months now, and like many others have found routing the cables a major problem. I'm now about to fit a new intel conroe rig inside. Does anyone have any tips to help me out?
Cheers
Remove the bottom fan (the one in the middle), makes it easier to route the power cables. Use lower HD cage rather than the middle one.
Remove all the plastic garb from the shelf.
