Antec P180 Fans
29 Sep 2004
Wilt of the Shire
Can anyone tell me what fans the P180 is supplied with and what fans I'd need to buy?
Thanks
3x120mm fans are included with the p180. You can fit 4 without modding the case. The 3 supplied are quiet and profide good airflow if setup correctly. Akasa 'ambers' are good fans, I got one to add to the three already installed.
I never bothered with using the fan in the lower PSU / HDD section, instead I moved this fan up to the top section.
So I had the fatter fan at the rear, one thin one at the top and one thin one at the front.
