- 4 Nov 2005
Hi,
The P180 stock Tricool 120mm fans are great, but... they are a pain to get to if you want to ramp up the speed for all three when doing heavy duty gaming (ie you have to open the case
The other day, I did a bit of foolish instant shopping at my local PC component shop, and bought an Coolermaster Aerogate 2, thinking that I could control the speeds using the aerogate front panel. However, looking at the Tricools, they don't have the standard power connectors to attach to the Aerogate, and the speed controls are just a dead end.
Anyone had this problem and figured out a mod?
Anyone figure out an easier way to drive the fans from outside the case?
Hope you can help
).The other day, I did a bit of foolish instant shopping at my local PC component shop, and bought an Coolermaster Aerogate 2, thinking that I could control the speeds using the aerogate front panel. However, looking at the Tricools, they don't have the standard power connectors to attach to the Aerogate, and the speed controls are just a dead end.
Hope you can help
