Hi, I've googled your motherboard and can't find the chipset cooler but it's likely to be 40mmx40mm which means most if not all of the OCUK 40mm fans will do, you should take a ruler to it and measure end to end, it really is that simple.
You might be better off asking in the motherboards board though
