Antec P180 or P182
20 Apr 2004
Hello,
I need a new case and very much like the look of the Antec P182. After looking around I also came across the P180 which looks very similar and is about £20 cheaper.
Could anyone tell me if there are any features on the P182 worth spending the extra money, or will the P180 be fine.
Thanks for replies :)
The P182 has space behind the mobo tray for keeping the cables tidy, and also has more access holes for sorting cables.
Have heard a few instances of people buying the P180 and it being a P182 inside the box. So you could get lucky!
Thanks a lot.
I'm not that worried about cable management anyway as not really a top of the range system I have so I'll go ahead and order the P180.
Be a nice bonus if I did get the P182 :cool:
Cheers :)
