antec p180
31 Aug 2006
London
received this case today
it's huge and very heavy :eek: :rolleyes:
anyway.... are the stock fans silent enough or do I need to buy some noctua fans?
will the Noctua NH-U12F fit into this case? I will buy this cooler today...
I would like to order the cooler for cpu tonight so maybe I'll save some on postage if I'll order all together...
I cant see why the Noctua wouldn't fit the case, it would be more down to your Motherboard I would say.
The fans with the case are ok, pretty quiet on low setting and a little noisy on medium but they are definately not anything special. If noise bothers you and depending on how hot your set up is you can get rid of some noise by blanking off the top hole.
Anyway great case and good luck with your build.
