Antec P182 and Fan Controller
11 Feb 2007
High Wycombe
I'm thinking of getting an Antec P182 to try and baby proof my PC (well thats what I'm telling the Mrs anyway) and I have a Zalman ZM-MFC2 Fan Controller in my current case. Does anyone know if the door would close alright or would it stick out too much?? The dial sticks out by just under 10mm.
Cheers.
Definately yes. My X-fi Fatality front panel sticks out more than that with bags of clearance.
Also don't forget you can vertical mount your CPU H/S with the P182! Mine knocks 5C off!
Thanks for the replys but its a pointless question now cos I've just measured the space in my desk and its just a couple of mm's too small for the case to fit into.
Could anyone suggest a nice looking case with a door on thats just a bit lower than the P182.
Cheers
Cheers
the top spoiler can be removed so that would cut down the hight of the case by about 20mm
