- 28 Jul 2007
sorry for all the help me threads but Im pretty new to this.
The instructions with the motherboard and case are terrible, not helped by the fact they seem like thay have been translated into english very badly.
Now the instructions say heading
'fan power connections'
'these connectors supply power to the cooling fans installed in your system'
CPU fan - which i believe i have correctly connected
SYSTEM FAN POWER CONNECTOR
AUX FANS 1-4.
The problem being thse are tiny little 3 pin connectors and the case fans have chunkier 4 pin connectors.
The only way I see possible to connect the 3 case fans is in this one socket what is the same shape named ATX4P1. HOwever like i said there is only one of these sockets and 3 case fans to connect. I have noticed however, that the case fan connectors can plug into each other in a stacking fashion if that makes sence, so is this how i plug them in.
I also have a square 4 pin connector coming from the power supply with seeminly no where for it to plug into, whats the deal with that?
And lastly, how do I know what is the positive terminal for the for the front panel switches and LED's.
Sorry to come across as an idiot, but these instuctions are terrible.
Thanks.
AUX FANS 1-4.
Thanks.
