- 7 Feb 2008
Exactly what it says on the tin, I've narrowed down my case choices to these two from a thermals/airflow, noise and future upgrades standpoint.
Now I'm having difficulty deciding between the two.
Spec wise, its going to get the following transferred into it from an Antec Solo.
Q6600 oc'd to 3ghz,
EVGA 780i mobo,
Noctua NH-U12P cpu cooler
a pair of 8800GTS512's in SLI.
Couple of hard drives
Corsair HX620
So I'm looking for opinions either way please. Please try to keep it between these two cases, I'm having enough difficulty deciding as it is
Thanks in advance
Q6600 oc'd to 3ghz,
EVGA 780i mobo,
Corsair HX620
Thanks in advance
Both cases will fit your components easily, just down to which case you prefer in looks...
