Antec P182 water cooled?
13 Sep 2007
Just a quick one really I wanted to know if a Thermochill PA120.3 radiator would be enough to cope with a Q6600, Northbridge and a 8800GTX as I recon I could squeeze one of these rads in my case (P182). But it would take up a lot of room and would be a bit of a wangle I have good air flow through the case but I would like to go water so that I could OC the CPU with better temps than I am getting from my TU120 extreme. I can’t fit a dual loop into this case unless you can show me how? so it would have to be a single loop hence the question.
Yes a PA120.3 will handle that loop but I am almost certain you won't get it inside the case.
A Black Ice GTS 360 with fans only just fits in the roof without blocking the mobo.
To dual loop you could put a thin rad in the roof and then a 120mm down in the bottom section where the HD cage would normally go.
thanls forthe quick reply marcus, food for thought there do you think a 120 rad would be ablt to take the heat dump from the 8800GTX? also has any one used one of these:
http://www.xspc.biz/baypump.php
was thinking of this with d-tek fusion and 120mm rad for the GTX to save some space.
and the triple rad for Q6600 ond northbridge
